Hey boys,
I have a 90 F250 7.5l 460 it started spewing oil from the oil cooler in front of the rad. Should I replace it, fiweld it) or try and bypass it? I only really use the truck for firewood and bush roads.Any help would be much appreiciated.
thanks
Chris
Bypassing it probably wouldn't cause any problems. But replacing it shouldn't be too hard or expensive either. I'd probably go that route.
And I suppose I should ask, but are you sure it's an oil cooler and not a trans cooler? Oil (gold fading to black) looks a lot different from ATF (generally red unless it's really old). But if it's a trans cooler I'd definitely replace it.
And oil or trans, I wouldn't consider fixing it (unless it's just a loose fitting).
If he is talking about having to run a different radiator hose it's definitely the engine oil cooler. When you take off the heat exchanger box, you have to run a longer radiator hose to the water pump to make up for the void.
I didn't go back through the 5 year old posts before this question, so someone might have been asking about an oil-to-water cooler there. But this poster didn't say anything about a radiator hose. They said
Originally Posted by Chris Gover Ford
... the oil cooler in front of the rad....
I know there could be an oil cooler in front of the radiator, but I've never seen one. And I know that LOTS of trucks have trans coolers in front of the radiator. So like I said, I suppose I should ask...
