Did you offset your engine for a Volare clip?
Old 09-23-2011, 06:37 AM
raerjim's Avatar
raerjim
raerjim is offline
Went to bolt my bare block back up in the mounts and to tranny so I can get some measurments to remove cobbled, PO fabbed motor mounts and weld in new MF offset pre fabbed mounts. (some assembly required) I replaced the crossmember trans mount with the only mount I could find that is close, but not exact replacement. It is about 1/2" taller, which is going to change my pinion angle. That and the fact that when I got everything in and bolted up, the angle now on the tranny puts the mount in quite a bind. I don't care for that. It will surely twist the rubber out of the mount in time. I have an aftermkt. trans crossmember. Did you have to relocate your trans mount holes on the X-member to relieve the tension?
Old 09-23-2011, 07:50 AM
gdub's Avatar
gdub
gdub is offline
I offset the engine and transmission about an inch to the passenger side. I built my own crossmember and offset the holes on it too.
Old 09-23-2011, 09:42 AM
jniolon's Avatar
jniolon
jniolon is online now
old and in the way
+1 on offset... mine was 2" and fabbed my own trans mount
BUILDING A NEW TRANSMISSION
john
ftlover90
13
04-17-2017 06:33 PM
Walwal44
03-25-2014 12:43 PM
93tankus
09-19-2009 08:21 PM
1955effie
06-24-2005 04:47 PM
Rcmgiasson
02-18-2003 10:15 PM
Quick Reply: Did you offset your engine for a Volare clip?
