Rear Fuel tank questions
Well I decided to move the fuel tank under the rear of the truck. Mostly because I discovered my fuel tank has a bunch of rust in it, and replacing it and moving it under the frame is probably cheaper. Not to mention I gain some storage behind the seat, can make the body look a little smoother, and I can get a few gallon larger tank.
Ive read the article from Skip Porterfield article Installing a Mustang tank in a 60’s vintage Ford about moving the tank. My question is do I risk having the frame rails twist on me slightly as I would either need to remove or modify the frame rail in the pic below.
I could modify the cross member like this:
But if it the frame will be strong enough without this piece in there, I will just remove it entirely.
I had planned on using a Mustang tank. Ive also seen that some have the sending unit in the bottom/side. The 71 Mustang tank has a the sending unit on the top. The older ones (64-70) are on the front side of the tank. Does that matter? Im worried primarily about possibly messing the sending unit up because it would be more exposed to the elements. I see that the 71 tank is a little more narrow so could possibly fit into the frame rail better as well. Thoughts on the tanks below?
The '71 tank More Information for SPECTRA PREMIUM F32A
The '70 tank More Information for SPECTRA PREMIUM F2
I also looked at a fuel cell, but most Ive seen are bottom sump or something just doesnt work out quite right. Any ideas on what I can use for a fuel cell would be great.
Thanks!
Thanks!
Any input on the tank? A narrower tank seems to be the answer here.
Look where the crossmembers are located... right at the leaf spring support. The rear weight of the truck and chassis forces are transfered to the axle from these points and the crossmembers are there to tie everything together. I think modifying the crossmember as you described would be better than moving it... and I'd say absolutely do not just remove it.
I moved mine
Hey i moved my original tank from behind the seat, flipped it around, cut the filler hos off and welded it on the otherside, then put the tank in the back of the bed behind the cab. I think it loks good and you eliminate the odor in the cab and then fear of getting gas all over you in a t-bone crash. I will cover it with a diamond plate cover also.The tank behind the seat was nt a good idea by Ford.
SuperDuty93
23
06-26-2011 11:43 PM
1966ford
10-13-2003 09:54 PM
