What is the best way to clean carbs?
Old 09-18-2011, 08:03 PM
fifty-two_f1's Avatar
fifty-two_f1
fifty-two_f1 is offline
I am rebuilding two holley 1904 carbs for my 52. They are corroded on the inside and was wondering if there was something that I could soak them in that would dissolve all that corrosion?
Old 09-18-2011, 08:06 PM
Jeff and Nicolle's Avatar
Jeff and Nicolle
Jeff and Nicolle is offline
Hi Jordan,
I use the gallon cans of carb cleaner, always does a good job on the stuff i have done in the past.
Old 09-18-2011, 09:44 PM
lexcoe's Avatar
lexcoe
lexcoe is offline
For years i have used lemon juice and water mixed 50/50. Put it in a pot and simmer just below boiling, but do it outside if possible, stinks a bit.
I have used this on motorcycle carbs many times, never ceases to amaze me how well it works. John
Old 09-18-2011, 09:51 PM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is offline
Commercial carb shops use a boiling solution of caustic (lye), definitely not for the home mechanic. But it is great for removing corrosion.
Old 09-18-2011, 11:04 PM
DumbLuck's Avatar
DumbLuck
DumbLuck is offline
The whole bottom section of my 1904 was pretty bad, including the throttle plate. I let it soak for 48 hours in a 50/50 mix of water and white vinagar. use a plastic container as it will eat thru tin trays and such. (don't ask, but my work table still has the marks) I used a large plastic coffee container. some scrubbing with a brass brush, rinse well with water, and she was good to go. Use compressed air to blow it dry really well including the few small passages. Be sure to have the little check ball and such out. I left the throttle plate in place. Definitely an outside project.
Old 09-18-2011, 11:35 PM
BlueOvalRage's Avatar
BlueOvalRage
BlueOvalRage is offline
Ditto on the vinegar and water. It cleans the corrosion up fairly well. It works faster if you have a way to heat the solution. Just keep an eye on it though. It could probably eat the castings up if the vinegar was too strong and it was left in for too long.
catimann
1947 and Older Ford Trucks
04-27-2019 08:59 PM
Hogtrapper
29
01-26-2015 09:31 AM
Fomoko1
04-20-2011 09:23 PM
rcav8or
09-13-2008 09:49 AM
team green
Garage & Workshop
15
08-10-2002 10:20 AM
Quick Reply: What is the best way to clean carbs?
