1970 F500 Np435 swap to 1978 F600
will a Np435 out of a 1970 F500 work on my 1978 F600 dump truck ??? From what I can tell from vin. the F500 has a 330 M/D engine ....my dump has a 330 H/D engine .....with split rear .... the F500 does not have the split rear .... are the bell housings the same on the two????? input shafts ....any help will be greatly appreciated ....
F600 trans.
Got the transmmission pulled from the donor truck F500 ,then pulled bad trans. from F600 and then installed donor ....
donor trans. works great ....I can use granny gear now where before I didn't use it because I figured it had some broken teeth on reverse/1st gear ....now my truck drives better then it ever has since I've owned it....
figured out what was wrong with the original trans........ can anyone say hand grenade ???? bout a third of the teeth were chewed up......
mustang_gt_350
08-25-2015 03:03 PM
3360stepp
10-31-2010 01:25 AM
