Mustang gas tank dimensions?
After deciding to purchase a new gas tank for my 55, I've run into some confusing information regarding dimensions of the 69-70 Mustang tanks. Are they 30 1/4" wide, 32 5/8", or 35" wide like some of the sites indicate for their tanks.
Would someone who actually has one of these tanks mind telling me what they really are. I'm not sure why the dimensions vary from vendor to vendor.
Thanks
Thanks
Thanks
Thanks
Sam
Got enough steel to carry a small military tank in the bed back there. It is certainly going to be stronger than stock!
Hey JB,
My bed structure was all rotted out underneath - I could have ordered a replacement bed but I really wanted the Bed & Cab to be original to 1950 so we did a little re-engineering to stiffen it up a bit. Needed a big piece of metal between the rear of the truck & the tank as well as we aren't running any bumpers. I've seen some guys on here put armor in over the top of the tank as well.
Ben
Ben
I used this info to install a 70 Mustang tank in my 48.
Made it super easy to install. Thanks John.
If I hadn't taken so long on this build, the tank I already had installed would have been ok. I had a 1971 Maverick tank already installed, which used straps to hold it in. It was a good fit, but when I realized that you couldn't buy a reproduction tank, I got to thinking (bad idea, I know) that if I ever had a problem with the tank I wouldn't be able to find a new replacement. Back in the 80's those tanks were not hard to find.
The Maverick tank had some damage on the bottom that I thought might eventually cause some problems
