Rear hubs on a 54, issue with re-drilling...need help
We are wanting to re-drill the rear to the 5x4.5" pattern...there's a 1 1/4" hole right where one of the 4.5" holes needs to be.
Anyone ran into this? Is the only solution to remove the existing studs, fill those, and re-drill right below them on the new pattern? Seems like that is a weak solution.
I'm having trouble finding new hubs to purchase...any donor vehicles that would be an easy swap?
(pic of hub in album, if i don't get it posted here correctly)
Have you just considered getting a set of those billet adaptors. I easily found a set on ebay for mine. Converted it from a 5 x 5 1/2 to 5 x 4 1/2.
Two 5 x 5.5" To 5 x 4.5" Wheel Adapters / 1.5" Spacers | eBay
The instructions that came with mine just said they had to be torqued to a certain value that I cannot recall. I imagine one could come loose in the same fasion as the wheel itself. But I certainly think re-torquing them from time to time would be a lot simpler than trying to redrill and recenter that hub.
Sam
Got4wd
100
07-18-2020 11:18 AM
Jim Heal
2004 - 2008 F150
11-02-2018 12:22 AM
