67-72 Engine Tune-up Specs
Old 04-05-2003, 12:03 AM
Mil1ion's Avatar
Mil1ion
Mil1ion is offline
I'm sure a few of you can let others know about this thread.
Old 04-06-2003, 10:48 AM
jor's Avatar
jor
jor is offline
Thanks for the specs, Mil1ion. I never seem to remember the tune up specs when I need them and these will come in handy.
jor
Old 04-08-2003, 10:10 PM
fordxxx's Avatar
fordxxx
fordxxx is offline
What should be the idle speed for a '72 302, automatic?
Thanks
Old 04-10-2003, 01:24 AM
Mil1ion's Avatar
Mil1ion
Mil1ion is offline
Good question!
500rpm in Drive <> with solenoid OFF <>or CEC valve on.
Old 04-11-2003, 12:58 AM
Scotty1's Avatar
Scotty1
Scotty1 is offline
he spec for the 360 and 390 is spot on for factory settings. But, inital timing seems to make more power and is easier to start at around 10 btdc. Try this and see if you don't get better results.
Scotty
Old 04-19-2003, 07:58 AM
Matt67's Avatar
Matt67
Matt67 is offline
In the order they apear from left to right, I know its: #cyls-Plug gap-point gap-dwell-????-Timing. Whats this figure in which most of them are 17-21? As a guess, I would say it looks most like a vacume reading, but your the one with the book.
Old 04-19-2003, 01:08 PM
Mil1ion's Avatar
Mil1ion
Mil1ion is offline
Very good question.
It is the Distributor Spring tension in ounces.
17-21 ounces
I appreciate you pointing that out.
I will add the Firing orders to that post now too.
Old 06-24-2003, 10:42 PM
packratt's Avatar
packratt
packratt is offline
Trailering
You wouldn't happen to have this chart for a '79 460 and 370?
I did a search and couldn't find one.
Thanks
Le
Old 06-24-2003, 11:11 PM
Mil1ion's Avatar
Mil1ion
Mil1ion is offline
At least the 460 specs ,it's on my web site.
You need to get the calibration code first then look for the specs.
Click the blue *Club FTE Member* on the left to access my site.
scroll to the bottom of page and click *Calibration codes & specs*
Old 06-27-2003, 04:35 AM
willowbilly3's Avatar
willowbilly3
willowbilly3 is offline
Just remember that the timing spec is only a guide line that was established when gasoline was a lot different than it is now. My 72 300 6 pings like crazy at factory spec and needs to be backed down 2 degrees. It is a fine line and if I back it down 4 degrees it has a noticable power loss. On this you need a good dial back timing light and check all your advanc specs as per the manual. I have a 1975 Motor manual that has all the information in it which has been reliable except for a typo or error on the valve adjusting procedure for 390's.
NateJDFord
05-13-2007 05:57 PM
Mil1ion
Alberta Chapter
19
09-09-2004 12:32 PM
Pheonix BlackWolf
10-29-2002 03:38 PM
Mil1ion
08-04-2002 01:11 AM
Mil1ion
New Member Introductions
07-08-2002 07:04 PM
Quick Reply: 67-72 Engine Tune-up Specs
