transfer case output shaft seal
I'm trying to replace the output shaft seal on a the transfer case of a 94 Bronco. (electric shift). Getting the drive shaft off was easy enough. There is a lock nut that the factory manual says is 30mm. My 30mm does not fit, and a 32 mm socket is too large in diameter to fit down around the wrench. What size is it really? I'm think I'll try getting a 1-1.4 socket tomorrow.
Are any other special tools required to remove the output seal?
BigSexy78
06-15-2017 09:05 AM
Nothing Special
05-05-2013 09:14 PM
cghstrojan08
04-22-2007 09:41 PM
nzabka
04-18-2006 04:28 PM
Skagit
11-29-2003 09:15 AM
