99 ZX2 A/C
Old 09-04-2011, 05:13 AM
billhutch's Avatar
billhutch
billhutch is offline
99 ZX2 A/C
Cold air gradually (4-5 months) declined to now blowing warm air. Compressor kicking on and off within seconds. Don't know if low on R-134 would cause comp. to do that. Have a gage but not sure where low side is and 50/50 ain't good odds. Any suggestions?
Old 01-28-2012, 06:57 PM
whitefordexplorer's Avatar
whitefordexplorer
whitefordexplorer is offline
this may be a bit late, but the low side is after the evaporator, follow the lines from the compressor, if one heads to the condenser (radiator looking thing in front of car) then thats the high side... you may want to have your low pressure switch checked before you add refrigerant, because too much will cause it to blow warm. also if you can, have a dye placed in the system if you do add fluid so you may find a leak later.
Old 01-30-2012, 07:48 PM
critterf1's Avatar
critterf1
critterf1 is offline
Hi side and lo side service fittings are different sizes. Low pressure WILL cause the compressor to cycle frequently. (fail safe pre-caution)
tab a
1997 - 2003 F150
24
08-20-2018 07:16 AM
sittinguy
Aerostar
08-06-2017 05:45 AM
muddingirl81
09-03-2013 05:30 PM
granny_rocket
07-22-2012 12:08 PM
npearman
1997-2006 Expedition & Navigator
01-25-2010 03:57 PM
Quick Reply: 99 ZX2 A/C
