Competition Diesel racing, sleds, dynos, power tuning and max performance.
Best Pulling Tire
Old 04-27-2011, 10:20 AM
Gus Erickson's Avatar
Gus Erickson
Gus Erickson is offline
Best Pulling Tire
I don't know if this has been beaten here before. I run a gas stock pulling truck. I have been running Mastercraft Courser MT tires and am way dug into the track. Due to budget constraints I am down below the top guys in horsepower. I am thinking of going to ATs so I can maybe spin them more. What are you guys running? Any thoughts? Diesel guys chime in too. TIA
Old 05-01-2011, 01:17 PM
2006lariat's Avatar
2006lariat
2006lariat is offline
In my neck of the woods ppl are running interco trxus sts tires. not sure if they are cutting them though!
Old 09-06-2011, 05:52 PM
van o's Avatar
van o
van o is offline
mud tires that are almost wore out. maybe a 1\4 of tread or so left.
Old 09-19-2011, 01:10 AM
garrickg's Avatar
garrickg
garrickg is offline
STS Truxus
BF Goodrich - These will allow a little more slip than the Truxus.
Any variant of the BFG. There are several out there that are cheaper. Also consider the BFG retreads? I'd say if the size is available, they might be an option too.
I have also used the Coouser CTs They are not that bad. They seem a little stiff to me though. The BFG will definately air down better. The Truxus seem to be a little more fickle about air pressure. They hook great though. Very nice, soft tire.
I am a 2.6" turbo diesel puller. I am dealing with more weight (8000# truck) than you are. I do have some gasser friends though. They have mixed feelings about the Truxus over the BFG. I suppose there is a split among the diesel guys as well. It all depends on the track conditions. I pull in KY IN and OH. We have clay. Hard, tight, parts breaking clay. The diesels in this area are some of the most competitive in the country. My experience with truxus, BFG and Courser CTs have been based on pulling in our high traction clay tracks, I have also pulled on the sandy clay tracks of IN as well as indoor tracks.
My dislike of the worn out MTs mentioned above was the lack of siping in the tires. The sipings are what grabs the track surface. Treads with more sipings wear out faster but grab harder. also the leading edge makes a difference. The sharper, the better.
I am sure I am preaching to the choir here....
There is my $.02 worth....
Hope it helps (or at least entertains)
-G
azfarrier
1999 to 2016 Super Duty
03-13-2017 06:16 PM
sgeorge
11-08-2016 03:30 PM
RAPR
6.7L Power Stroke Diesel
09-12-2012 02:51 PM
ray pampena
66
01-07-2010 06:52 PM
WickedSharp
25
02-14-2009 08:19 PM
Quick Reply: Best Pulling Tire
