Firewall Insularion Pad
Does anyone happen to have a firewall insulation pad they would be able and willing to make a template oF? I need to make a insulation cover for the inside of the cab and do not want to spend the $$$ on an ABS one. What has everyone else done to cover their firewall. Thanks for the help and input it is always appreciated.
I sprayed my firewall with LizardSkin, added a layer of Dynamat Extreme, and then covered it with a layer of closed cell foam and mass loaded vinyl as soundproofing. Boom Mat makes a soundproofing product that has a leather-look outer skin that would probably look good if the firewall area is exposed. Most trucks today are using panels to hide the underside of the dash though.
Not much to look at, the MLV soundproofing is the last layer applied and it is just black vinyl. The LizardSkin is sprayed on and is about 1/8 inch thick, the Dynamat is another 1/8th inch, the CCF and MLV together add another 1/4 inch. All in all the whole system is thinner than the original jute padding that came from the factory. Now that I think about it the MLV looks a lot like the black painted cardboard that was OEM.
I bought an fiberglass firewall cover with a ford oval embossed in the center. I got it from Dennis Carpenter. It's moulded to fit the hump in the middle. I never used it because of an aftermarket heater / ac unit I put in left little room for it and I didn't want to cut it up. It's new still in the original plastic bag. If you're intrested PM me.
1964FORDTUF
09-20-2016 11:25 AM
Midnite1987
09-29-2012 04:37 PM
fergusonicford
11-03-2008 04:58 PM
