Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1961 - 1966 F-100 & Larger F-Series Trucks > 1961 - 1963 F100 Unibody
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1961 - 1963 F100 Unibody 1961, 1962 and 1963 Ford F100 Unibody trucks
  #1 (permalink)
Old 08-19-2011, 01:36 PM
eddie5280 eddie5280 is offline
Garage is empty, add now
eddie5280 is starting off with a positive reputation.
Changing engine size in 1961 F100
I have a 1961 F100 that needs a new engine and clutch. Is it possible to replace the 292 with a 312 engine without any modification or major changes? Also where can I purchase the new engine, what websites, stores etc. would be a good source for finding a new engine? Can I upgrade to a 4 barrel carb instead of a 2 barrel? I will replace the clutch at the same time - where can I find one that will work for this truck? Thank you for your time.
  #2 (permalink)
Old 08-19-2011, 08:29 PM
spurredon's Avatar
spurredon spurredon is offline
spurredon has a good reputation on FTE.spurredon has a good reputation on FTE.
Why not just rebuild the 292?
  #3 (permalink)
Old 08-21-2011, 08:38 AM
I could rebuild it also. Do you think that is a better option? I just thought replacing the engine would be a faster, better and a little more econimical solution. What are the advantages/disadvantages of rebuild vs replace?
  #4 (permalink)
Old 08-24-2011, 07:37 PM
Bushbee Bushbee is offline
Bushbee is starting off with a positive reputation.
In this situation, since the Y-block Ford has not been produced in a gazillion years getting a used running engine could be a big gamble, unless it is a reputable shop that either built it, or knows who built it. Good machine shops can be hard to come by. Especially those that know the ins and outs of a Y-Block Ford. If you take yours to a good shop that is familiar with Y-Block Fords you really can't go wrong. It will probably be more expensive up front, but a good rebuild, taken care of with proper maintenance can be well worth it. Not sure what part of the country you're in, but there is a shop in Englewood, Colorado (Denver area) that does phenomenal work, and the owner/machinist knows every Ford motor like the back of his hand.
  #5 (permalink)
Old 08-29-2011, 05:06 PM
jhooch's Avatar
jhooch jhooch is offline
jhooch is gaining momentum as a positive member of FTE.
Finding a 312 is going to be the tough part. These were used in T-birds and cars. Dimensionally they are the same as your 292 (and 272) so the swap would be easy. Check around on Ebay and Craigslist, maybe Hemmings Motor News. Like the above post said, when buying a used or rebuilt engine, do everything possible to make sure the source is reputable.
__________________
Jeff
'05 Excursion LTD 6.0 4X4, 01 F250 7.3 4X4 Crew
73 Bronco, 66 F100 CC LWB, 62 Uni LWB
69 Cobra 428CJ, 4-speed, 64 Fairlane 2dr Post
See my other projects at: www.fullsizeford.com
  #6 (permalink)
Old 08-31-2011, 04:54 PM
fordman67 fordman67 is online now
1996 Ford F-350
fordman67 is gaining momentum as a positive member of FTE.fordman67 is gaining momentum as a positive member of FTE.
I have not looked in a while but I sold a 57 312 ecz main cap proper and verified engine. It was torn down and in excellent condition only needing gaskets,rings,bearings. it went for 925 on ebay. I could not believe it went that high.I kind of wish I has reassembled it and put it back in my truck....
__________________
1996 f-350 cclbsrw4x4 psd
41 ford super deluxe tudor
64 fairlane sports coupe
1925 T tudor sedan
Tags
1960, 1961, 1966, block, desile, dimensions, engine, f100, find, ford, motor, size, tire, truck, unibody
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
