Missouri Chapter Join Chapter , Leader:77&79F250
The ol 87 getting new motor
Old 08-15-2011, 12:34 AM
460429_freak's Avatar
460429_freak
460429_freak is offline
Well got old motor out,man was the hypermax turbo a pain to get off....new motor installed but not hooked up still have to order some parts from hypermax.... Ever see a motor crack one head between every valve?
Old 08-15-2011, 08:41 AM
earthquake68's Avatar
earthquake68
earthquake68 is offline
Sounds like alot of pressure from the turbo causing the heads to flex. It could also be excessive heat from a lean condition. (common with a forced induction engine not properly tuned) My suggestion is thicker castings/aftermarket heads and then stud everything with ARP studs. ...and then make sure you have enough fuel getting to engine.
Where's the pictures?
Old 08-15-2011, 04:39 PM
460429_freak
On the iPhone it's hard to get them to work have to wait till I'm on my laptop
Old 08-17-2011, 03:04 PM
460429_freak
as requested
Bmoodie10
05-21-2018 10:45 PM
Macmathews
04-07-2017 04:56 AM
mos68x
77
03-05-2016 10:10 PM
Jesser02EX
76
06-11-2015 11:49 PM
joe f350
24
04-19-2011 09:11 PM
Quick Reply: The ol 87 getting new motor
