Ford Truck Enthusiasts Forums
-   Missouri Chapter (https://www.ford-trucks.com/forums/forum104/)
-   -   The ol 87 getting new motor (https://www.ford-trucks.com/forums/1091619-the-ol-87-getting-new-motor.html)
460429_freak 08-15-2011 12:34 AM
Well got old motor out,man was the hypermax turbo a pain to get off....new motor installed but not hooked up still have to order some parts from hypermax.... Ever see a motor crack one head between every valve?
earthquake68 08-15-2011 08:41 AM
Sounds like alot of pressure from the turbo causing the heads to flex. It could also be excessive heat from a lean condition. (common with a forced induction engine not properly tuned) My suggestion is thicker castings/aftermarket heads and then stud everything with ARP studs. ...and then make sure you have enough fuel getting to engine.
Where's the pictures? :)
460429_freak 08-15-2011 04:39 PM
On the iPhone it's hard to get them to work have to wait till I'm on my laptop
460429_freak 08-17-2011 03:04 PM
as requested
https://www.ford-trucks.com/user_gal...id=244306&.jpg
https://www.ford-trucks.com/user_gal...id=244308&.jpg
https://www.ford-trucks.com/user_gal...id=244307&.jpg
© 2018 MH Sub I, LLC dba Internet Brands
