Trimming out carpet around pedals and steering
Old 08-14-2011, 06:07 PM
teardropty's Avatar
teardropty
teardropty is offline
I am looking for a new way to trim out my carpeting around the pedal arms and steering column shaft on my 54. In the past I have carefully trimmed out the carpet and melted the edges of the carpet to prevent unraveling. How does everyone else do it? Anyone know of some good grommets that may work? Any ideas?
Old 08-14-2011, 08:30 PM
dongc1's Avatar
dongc1
dongc1 is offline
I bought some of the grommets to go around the dimmer switch. They worked fine around the brake & clutch pedals.
Old 08-14-2011, 11:04 PM
mechmagcn's Avatar
mechmagcn
mechmagcn is offline
Mid-Fifty sells some trim rings for this purpose but I made my own from some .063 aluminum and a piece of an inner tube to seal around the pedals.
Old 08-15-2011, 08:32 AM
Old F1's Avatar
Old F1
Old F1 is offline
................................from where?
Old 08-15-2011, 09:02 AM
teardropty's Avatar
teardropty
I like the fab idea. I have checked out Mid50's stuff but I wanted something a little different. Got a source for the dimmer switch grommet? Thanks!
Old 08-15-2011, 06:32 PM
dongc1's Avatar
dongc1
dongc1 is offline
I think this is where I got them. There are several upholstery supply places that have them.
Dimmer Switch Grommet
Old 08-15-2011, 09:10 PM
Old F1's Avatar
Old F1
Old F1 is offline
Not sure the grommet will work for a floor mount petal as it arcs and needs a bit more room. I’m going to try a model A emergency trim plate for the brake petal, they also make a bigger trim ring for the shifter that might fit the steering column, same supplier.
Ford Model A Emergencey Brake Trim Plate 28,29,30,31 | eBay
Old 08-15-2011, 10:06 PM
49fordpickumup's Avatar
49fordpickumup
49fordpickumup is offline
Old F-1, that plate reminds me of a house metal light swirch cover that has the opening enlarged and cheap to buy. You could put a piece of inner tube under it and split the inner tube for pedal movement.chuck
Old 08-15-2011, 10:14 PM
dongc1's Avatar
dongc1
dongc1 is offline
My pedals are the original floor mount pedals and the dimmer switch grommet works fine.
Old 08-16-2011, 08:31 AM
teardropty's Avatar
teardropty
That's what I was looking for. Thanks for the ideas guys.
Old 08-16-2011, 09:58 AM
Old F1's Avatar
Old F1
Old F1 is offline
Originally Posted by 49fordpickumup
, that plate reminds me of a house metal light swirch cover. chuck
……….Except smaller and SHINNY!
Old 08-16-2011, 10:47 AM
SFAllison's Avatar
SFAllison
SFAllison is offline
In the past, I have used a soldering iron to create any holes in the carpet for bolts, etc.
Old 08-16-2011, 08:40 PM
49fordpickumup
old F1, shinny is good. I was thinking of POR-15 and black paint to match black carpet. I was not trying to offend. Just thinking of cheap and availability. chuck
Old 08-16-2011, 10:36 PM
Old F1's Avatar
Old F1
Old F1 is offline
Chuck, no problem. Some of us are like Ravens or Crows, if it shines we like it! (..and sometimes not too much separates the animal species either . )
jniolon
12-30-2017 09:07 PM
Keithfriend
06-10-2014 06:30 PM
Greg M-47
04-04-2013 08:52 PM
hivolt5.0
02-04-2009 01:03 PM
Quick Reply: Trimming out carpet around pedals and steering
