My F-250 Build-Up
#61
Yesterday I tried my sisters 2010 Taurus key (same as pictured, with the built in buttons, etc) and it was too fat to fit into the ignition. Not the key part, the fob part. The opening wasn't wide enough to allow it to seat all the way down.
I can't speak on the programming part because I didn't try it, but I suspect it wouldn't work.
they used some sandpaper and clearanced ignition...not sure how much I want to do that on the truck. thanks for pointing that out. I still haven't gotten my key cut
#62
Been awhile since I did an update. Got some goodies in, some of it was even installed. Haven't mustered up the required care factor yet to install some.
Installed:
Installed:
Gearheads SRL Tune
MBRP "Test" Pipe
Glowshift Gages (Fuel Press, Boost, EGT, Oil Press)
Scangauge II
Black Chrome Exhaust tip (5" by 12")
Bushwacker Pocket Flares
Custom Mudflaps using Ford floormats
Waiting, but I'm lazyMBRP "Test" Pipe
Scangauge II
MBRP 3.5" Downpipe
XScorpion Voltmeter
Ford Blue Spring Upgrade Kit (one with new cover)
6.4 Banjo Bolts
XScorpion Voltmeter
6.4 Banjo Bolts
#63
I apparently haven't touched the truck since October.
Just installed the Blue spring mod this afternoon. I was watching my fuel pressure yesterday and saw it dip to <50 psi several times
scared me
30 minutes of time and now she is upgraded. solid 72-74 psi at light throttle, 65 psi at WOT.
holy hell this should have been the first upgrade. truck runs smoother, and she feels...peppier...much more responsive. Almost as much a difference as going from stock tuning to my SRL tune. Wish I'd done this earlier
scared me
#65
13,6xx miles today! I've been deployed a bit this year so it isn't getting driven much
1F-5F in town
5-6F at 60 MPH for ECT/EOT spread. I've seen up to 9F for short periods...but never stays there
EGR is currently turned off in PCM. Cooler and valve will stay installed. Most likely will do sneaky delete when/if I have to tear into the motor
1F-5F in town
#67
The PATS part doesn't work on 99-07 superduty. only on 08+
I bought the key used and cut the old "cut" key out...then epoxied another new uncut blank into it's place. I've done this before on my 09 Mustang key and it worked perfectly
you program the clicker part just like you would an other remote/clicker for your Ford.
only problem with the integrated key/clicker is that it doesn't fit the key slot on the 99-07 trucks. It's too wide. A real shame too. I went through all the effort to retrofit the damn thing and it won't work in my truck. Guess I've got it as a spare key for my Flex though. So there is a bright side.
#68
Apocalypse
1999 to 2016 Super Duty
08-27-2014 07:02 AM
gearhed1971
08-23-2009 09:29 PM
