Pilot bushing removal
First, find a rod, bolt, or shaft that is the same diameter as the ID of the pilot bushing. I have even used my clutch alignment tool before. Second, pack the hole in the pilot bushing full of grease. Third, insert the rod, shaft or whatever into the hole in the pilot bushing and smack it with a big hammer. This will create hydraulic pressure behind the bushing and pop it out. It may take several times of packing and smacking to get the job done but it will usually work. Redneck way of doing it I know but it works!!!!!
But he said it is hour glassed now, so maybe find a slide hammer with a small enough hook attatchment or screw in attatchment and see if you can screw it in to the side of the bushing. Also since the grease will oozzz out around said inserted shaft or bolt try the wet toilet paper trick shoved in there instead of grease it will work also. Its a bronze/oil lite bushing and if all else fails maybe you could chisel at it till it breaks apart (get those safety glasses on for any of this)
on
Sid138
09-12-2012 10:06 AM
jack71
11-13-2007 05:30 AM
Denver351W
03-12-2007 07:40 PM
wick246
23
09-01-2006 02:01 AM
alankirby
03-22-2006 11:30 AM
