Is a 5.0L flywheel the same as a 5.8L flywheel
I'm in the middle of swapping in a standard 5 speed transmission
(ZF-42) from a 1994 F250 into my 94 F150 5.0L (302) 4x4 that originally had a automatic (E40D)
My question is the flywheel from the 5.8L going to work with my 5.0L? It is a 164 tooth ring gear and externally balanced.
You have 28 oz vs 50 oz. Be careful of the years of each engine too. The bellhousing will also possibly be different and thus a different number of teeth. Ford does us all a disservice with the multiple flexplates they use. Try finding a 50 oz flexplate with 157 teeth to mate to a 1968 Mustang C4 trans..... Grrr.
E8TZ-6375-D .. 5.0L M/T Flywheel / Marked: E8TR-6375-AA
Applications: 1988/96 F150/250 & Bronco.
E0TZ-6375-A .. 4.9L M/T Flywheel / Marked: E0TR-BA
Applications: 1980/96 F100/350 & Bronco.
The only thing that is the same 4.9L/5.0L/5.8L is the 164T M/T flywheel ring gear (C5AZ-6384-D).
The 4.9L (300 I-6) M/T flywheel is not the same as a 5.0L (302). The 5.0L M/T flywheel is not the same as a 5.8L (351W).
OK this is good help, My 5.8L flywheel is marked E8TR-BA don't think this is the part number of it is it?
I called Ford today and they said the flywheel is discontinued??
Should i just get one from napa? And What should i get? A 1994 F150 5.0L manual flywheel? or should i get a 1994 F250 5.0L manual flywheel?
As the ZF-42 5 speed was only offered in F250 and F350
On the centerforce web site sounds like the F150 ,F250, F350 all use the same clutch between 5.0L and 5.8L so i shouldn't mess that up right?
www.rockauto.com
Ford
1994
F250
5.0L
Transmission-Manual
Flywheel
$44 to $104
...take your pick. ;)
Alvin in AZ
Ford
1994
F250
5.0L
Transmission-Manual
Flywheel
$44 to $104
Alvin in AZ
No, it's an ID engineering number, not a Ford part number. Marked w/ID number: E8TR-6375-BA = Ford part number E8TZ-6375-C
Considering that the last MSRP was a horrid $457.77 (dealer net cost was bad enough @ $274.66), I doubt you woulda bought one if it was still available.
Did you see what I typed in post #6? It's the same tamale. 1988/96 F150/250 & Bronco 5.0L: E8TZ-6375-D
Alvin in AZ (retired RR 'signal ape' and a well known raconteur on Ford truck websites) gave you a ref for rockauto.
jeepinrocks
11-16-2003 10:49 AM
Brian460
06-26-2003 05:23 AM
