Starter, solenoid, or ground issue?
my truck sometimes starts fine. The often when it hasn't been started for the day, it doesn't. I turn the key, can hear the fuel pump pressurize and hear a loud click...like a solenoid. I turn the key back and forth several times, it keeps doing it and eventually it will turnover and run fine.
I had the same problem a couple years ago and replaced the starter and it seemed to go away for a while, but slowly started back again. Could it be the starter again? I have a feeling it might be something else, like a grounding issue or I think there are two solenoids? any ideas?
I would check the wire that runs from the solenoid to the starter. If it has corrosion on it, it'll do that. My truck does that too sometimes. If the starter operates how it always did (meaning normal speed and sound) when it actually decides to turn over, I'd think it's ok. If it's sluggish, it might be bad. But check that cable and even the other battery cables for a loose or dirty connection. Sometimes a solenoid can do that too
Received 3,110 Likes
on
Best thing to do would be to get a starter with the post style connection for the relay wire. That spade style connection is the problem as it's much more susceptible to corrosion.
You can try cleaning the connection but i'm sure that day will soon come again when you're sitting there turning the key back and forth waiting for it to catch.
OK, the issue continues. I cleaned up the spade connection...even replaced the spade connector and it is still doing the same thing. Checked the voltages with a meter and I have 12 Volts at the starter, but with the key turned to the starter position (where it would normally turn over) I have nothing at the spade connection...I would think it should be 12 volts when the key is turned all the way to start. The fendrer mounted relay is clicking when the key is turned.
Does anyone know where the signal to the spade comes from? is it the relay? or maybe the ignition switch? I think whatever it is might be the problem.
again, if I turn it back and forth enough time, it will eventually engage the starter and startup.
I just replaced the solenoid on the inner fender of my 93 T-bird Friday, it was acting exactly the way you describe..
It would clunk every time you turned the key to the start position, but nothing happened. Checked voltage out of the solenoid to the starter, with the key in start position, you guessed it NUTTIN' Changed it out and it hasn't missed a lick since..
Hardest part of the job was finding a solenoid NOT made in China!!!!!!!
Glad to hear it's fixed. One other thing to keep in mind for the future: check the ground cable connection to the engine block. We had in a 95 E150 5.8L and it was kicking the tech's ***. Put a battery in, a starter, a solenoid, still had a constant click at the starter. Another tech looked around and noticed some corrosion around the ground cable terminal, along with the bolt being loose. On this particular vehicle the cable connects to the block on a pad below the air pump.
96broncoXlt
1978 - 1996 Big Bronco
15
11-27-2012 12:37 AM
Rivergreen74
20
03-10-2012 12:13 PM
allisonmo2
03-12-2009 08:52 PM
