Automatic Transmission Break-In?
Old 07-25-2011, 09:44 PM
yz450fpilot's Avatar
yz450fpilot
yz450fpilot is offline
OK boys I will be getting my truck out of the Ford dealer tomorrow with a remanufactured transmission. I have searched the forums and have not been able to locate information regarding break-in of a new transmission. Is there a recommended break-in procedure for a new transmission?
Thanks for any input!
Old 07-26-2011, 04:16 AM
stuart1's Avatar
stuart1
stuart1 is offline
Nope, drive it.
Old 07-26-2011, 04:30 AM
AlaskanEx's Avatar
AlaskanEx
AlaskanEx is offline
Bleed Ford Blue
my guy says to drive semi sane for the first 100-200 miles. after that drive as you normally would. not sure how much you really need to do that..but i have and have had no issues with my rebuilds.
Old 07-26-2011, 04:33 AM
ford390gashog's Avatar
ford390gashog
ford390gashog is offline
If it was rebuilt right it should not have any issues!! Drive it as you always would!!!
Old 07-26-2011, 04:49 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Mark Kovalsky is online now
Received 1,576 Likes on 1,054 Posts
There is no break in procedure required on an automatic transmission.
Old 07-26-2011, 07:47 PM
yz450fpilot
Thank you for all your input.
Old 08-08-2011, 08:13 PM
yz450fpilot
I need your help with my new remanufactured transmission. Had a factory ford remanufactured transmission put in at a ford dealer and after driving less than 200 miles there is trouble with the trans. The dealer wants to only repair the trans and I'm telling them I want another reman put in the truck which they refuse to do. Does anyone have any advise as to what i can do to get another remanufactured trans put in?
Old 08-08-2011, 11:37 PM
85e150's Avatar
85e150
85e150 is online now
Received 1,595 Likes on 1,300 Posts
Which trans and what is the trouble?
Sometimes your insistance that it be fixed and refusal to take the malfunction as "normal" will sway them towards another full swap.
My replacement had a flare in it--"normal" for the 5R55E it seems, but I "fixed" that with some snake oil.
I also noticed they installed an in-line filter in the cooler lines. Hhhhmm, what do they fear about the new trans and their R&R job....
Old 08-09-2011, 04:34 AM
Mark Kovalsky
Ford requires an inline filter to maintain the warranty on remanufactured transmissions. It's impossible to get every bit of trash out of the coolers so the filter protects the new trans from debris left over from the old trans.
AzBlueOval
6.7L Power Stroke Diesel
04-05-2013 11:08 AM
NY-Ford-Lifer
01-09-2010 07:20 PM
CyberJay
1999 to 2016 Super Duty
28
04-05-2005 08:38 PM
roybb
02-02-2000 03:18 PM
Quick Reply: Automatic Transmission Break-In?
