how to make a grill shine
#46
Not trying to jack this thread and I agree with everything on here (oh and yes your grills look awesome ! I saw them on ebay before I saw this post great job! ) I have a "How to" on another site I will see if I can copy and paste it here. It's has one other way of going about this that I haven't seen on here yet.
Thanks for your post, that sand blaster looks cool would have to build one 8 feet or so long to fit the whole grill in at once. Do you have to use a certain kind of sand, or can you just go to the river and get some? I will probally build a box and line it with plastic to do the drano dip for the grill. I dipped the bezel in some just to see if it worked and it helps but still have to sand some. I messed up and dipped it again to get the other half(did not get it all in the first dip) got some of the bare aluminum in the drano,and well it ate the bare aluminum and left a perfect line were it was in the drano. Looks like a dotted line. I have sanded and sanded on it with no results. How much material does the sandblasting take off? Or does that depend on type of sand used?
#47
Just so you know those grills on ebay are Gangstakr's, not mine.
I use glass bead in my blaster but a fine wire wheel on a grinder would work to. Just make sure it's a "fine" wire one, your just trying to cut through the coating not into the aluminum. Oh and use a full face shield when using any wire wheels.
<o>
Both the wire or the sand/glass bead are just roughing it up and removing most of it. you will still have to sand off the left over and sand it smooth.
#48
#50
really need to get me a hand grinder been a parts changer most of my life just now trying my hand at restoring things learning that I need to go buy more than wrenches and sockets to be able to do it all myself lol.
Thanks for all the response on this, without it I would have gaven up by now you guys keep me going.
#54
