tjbeggs rear disk conversion
Old 08-04-2011, 07:28 PM
wildstang's Avatar
wildstang
wildstang is offline
VT Chapter Ldr
I see in your sig you list rear disks. How did you get them and do you have an e brake? Thanks.
Old 08-04-2011, 07:48 PM
tjbeggs's Avatar
tjbeggs
tjbeggs is offline
How did I get them....Well I built them of course!
Here is two threads about the matter.
https://www.ford-trucks.com/forums/6...-are-here.html
https://www.ford-trucks.com/forums/9...ion-2-0-a.html
No Parking brake on mine. not sure if I ever will. But Read the Fordmann.com link I posted and it gives a very good idea of what is needed for the current set up I am running. I did a much easier build than they did. I just started from scratch by building the new Super Duty style axle flange that I then welded onto my axle tubes.
Old 08-04-2011, 07:56 PM
wildstang's Avatar
wildstang
VT Chapter Ldr
Awesome thanks a bunch Tim.
Old 08-05-2011, 09:53 PM
Talyn's Avatar
Talyn
Talyn is offline
Anyone know if you can convert an SD axle to our bolt pattern?
Old 08-05-2011, 10:00 PM
Talyn's Avatar
Talyn
Talyn is offline
Thats a dumb idea. n/m haha
Can't use same bolt pattern and SD rotors. Doh!
Old 08-05-2011, 10:03 PM
fordpride's Avatar
fordpride
fordpride is offline
Would the E99 van reared work
Old 08-05-2011, 10:14 PM
Talyn's Avatar
Talyn
Talyn is offline
Hmm, you speaking of something I haven't looked into.
More info?
Old 08-05-2011, 10:22 PM
fordpride's Avatar
fordpride
If not the whole readend could you use everything of the rear and swap it over to a OBS
Old 08-06-2011, 07:34 AM
Talyn's Avatar
Talyn
Talyn is offline
are you saying the E99 van had old bolt style but disk rear?
Old 08-06-2011, 11:45 AM
fordpride's Avatar
fordpride
Oreillys site shows it to have a bolt circle of 6.50 for a 99 e250
http://m.oreillyauto.com/img?url=htt...-1.jpg&ttl=30d
Old 08-06-2011, 12:12 PM
wildstang's Avatar
wildstang
VT Chapter Ldr
The big hold up would be the backing plat to bolt the calipers to. May have to still do what Tim did.
Old 08-06-2011, 12:28 PM
ford390gashog's Avatar
ford390gashog
ford390gashog is offline
The vans do have disc brake rears and the 6.5 x 8 pattern. But the sterling axle was never used to this day in vans! They are all Dana axles so you would have to measure the spring perch width and driveshaft to see if it would work.
Old 08-06-2011, 12:56 PM
joe_13894's Avatar
joe_13894
joe_13894 is offline
Van frames are different in width so you would have to cut off and weld the spring perches.
Old 08-06-2011, 12:58 PM
joe_13894's Avatar
joe_13894
I've always wondered if you did that if you could get the parking brake on too? From what I understand the parking brake on the E99 is a drum on the inside of the rotor. If you could get both on that would be cool.
Old 08-06-2011, 04:51 PM
wildstang's Avatar
wildstang
VT Chapter Ldr
Superduty is Same setup.
Quick Reply: tjbeggs rear disk conversion
