New to FTE forum
New to FTE forum
Hello All,
I'm new to the forum and looking for info. I have a 64 F100 4x4 w/ a 390 and I'm looking to upgrade axles and steering. Where can I find some basic specs like frame width, spring perch width, for 61-64 trucks and 67-75 F250s? Everything I can get my hands on suggests that the 65-66 F250s had the same dimensions and setup as the 61-64 F100s (except from the knuckles out). Did Ford change dimensions in 67? My info shows spring perch width as 31.5" for those years (67-75). Thanks for any light you can shed on this.
Brian in NE Cali
Brian in NE Cali
Welcome to FTE Brian!
1961/72 F100/350 rear frame rail width (behind the cab): 33 1/2."
1973: Ford widened the rear frame rail width on F100/350's to 37 1/2" except on the following F250/350's which retained the 33 1/2" rear frame rails:
1973/76 F250 4WD, 1977 F250 4WD before serial number Y20,001 (all High Boys) / 1973/79 F350's on the 140" wheelbase.
1977 F250 4WD from serial number Y20,001, 1978/79 F250 4WD (all-not High Boys): 37 1/2" rear frame rails.
Dueling Bill W(ilson) frame rail info:
This Bill Wilson sez: All 1973/79 F100/150 4WD's have 37 1/2" rear frame rails, as do the non High Boy 1977/79 F250 4WD's.
Disc brakes were first offered for F100/250 4WD's in 1976.
1973/76 F100/250 4WD & 1977 F250 4WD (before serial number Y20,001) used Power Assist P/S. This system has a separate control valve and ram cylinder.
The manual gearbox is used because it has nothing to do with Power Assist. Two totally different types of Power Assist P/S were used on these F250 4WD's.
1973 F250 4WD, 1974 F250 4WD before serial number T80,001 used Garrison Power Assist P/S.
1974 F250 4WD, 1975/76 F250 4WD, 1977 F250 4WD (before serial number Y20,001) used Bendix Power Assist P/S.
Be aware that replacement parts for Power Assist P/S are all obsolete, expensive, difficult/almost impossible to find, depending on what's required.
Updating 1961/64 suspension, adding power steering and etc. FTE member Garbz2 is the one to ask about these mods.
Originally Posted by Bill W(ilson)
Only on the 2wd trucks did they widen the frame.
100 mile 12valve
17
02-23-2014 08:25 AM
jim collins
06-14-2009 02:58 PM
velcro7279
03-04-2005 11:16 AM
ajb
01-14-2001 10:37 AM
