Hydroboost Questions
Old 02-06-2017, 03:13 PM
Pork_Chop50's Avatar
Pork_Chop50
Pork_Chop50 is offline
I am working on compiling a parts list for converting my 1994 F350 to hydroboost brakes. I've searched and got most of the information I need, but had just a couple questions I haven't been able to answer so here's hoping I can get this answered and it helps anyone else contemplating the swap.
1) I will not be converting to rear disk, but keeping my drums. Thus far it seems I should retain my current master cylinder as it has the correct proportioning valve and bolt it to a hydro-boost booster. True or False?
2a) There are a few choices for rear wheel cylinders on the drums. The best performance seems to be using dually cylinders and 3" shoes on the SRW drums. True or False?
2b) If True are the dually cylinders direct fit bolt on's as I've read that the steel brake line fitting is a 7/16" SRW and 3/8" DRW or vice versa?
3) Finally I have read there is a break in the hose configuration from pump to gear to booster due to build date. And I have read there is not a break. Can this be confirmed if there is a such a break? I have the P/N for either way, just need to know which should I get.
Old 02-06-2017, 06:02 PM
tecgod13's Avatar
tecgod13
tecgod13 is offline
1) True, use your existing master, but you'll have to enlarge (slot) the holes as the hydroboost bolt spacing is wider than the vac booster spacing.
2) no clue on dually vs srw brakes, never heard of someone messing with that. You'd probably get more out of switching to disc rears if you think you need to upgrade the rears
3) sorry don't know that one either, at some point they do switch over to I think metric sized fittings, and the mounting for the hydroboost unit changes, but that might be when they went to calling 250's and 350's Superduty...?
There is a ton of useful info in the following thread:
https://www.ford-trucks.com/forums/1...st-brakes.html
Its what I referred to during both of my conversions (the second just a few weeks ago went much smoother than the first)
Old 02-06-2017, 07:19 PM
IDIoit's Avatar
IDIoit
IDIoit is offline
my 93 hydroboost set up, on my 87 does not have a brake in the lines.
but my 01 SD does.
I would go without a brake. the less connections, the better.
do you have the pedal? they are different than vacuum boosted brakes.
the pin is higher on the hydro pedal.
Old 02-06-2017, 08:13 PM
Pork_Chop50
That is one of my go-to's for when this happens, but thanks for including it. Your answers are appreciated also, I hope this helps others looking.
I don't have the pedal yet, but I will hit the yards to find one in the very near future. Worse case scenario I will go with the drill/move/weld technique if I come up empty on the proper pedal.
Old 02-06-2017, 10:05 PM
Macrobb's Avatar
Macrobb
Macrobb is offline
Here you go: https://www.ford-trucks.com/forums/1...ght=hydroboost
I literally did everything that's not recommended, and it still worked just fine:
1. Used a HB unit off a '03
2. Used stock PS pump, and used a return tee.
3. Used stock pedal, no mod there.
4. No modded brakes.
I can lock up all four wheels on dry pavement if I want to, without needing to pull on the steering wheel to get the leverage. It's great!
It's also a lot more 'linear' feel-wise.
Dave145
12-22-2017 01:00 AM
Corndog3217
03-22-2016 08:15 PM
norvillebob
11-17-2006 02:22 PM
imlowr2
05-23-2005 09:21 AM
psychlopath
08-10-2004 12:26 PM
Quick Reply: Hydroboost Questions
