37 inch hummer wheels
07-27-2011, 06:18 AM
on
Will 37 inch h1 hummer wheels with 8 lug rims fit on my 79 f-250 dent with a four inch lift?
07-27-2011, 06:25 AM
Nope!!!!!! The hub centers are to small to fit! You need large center wheels like used on Ford/Dodge trucks.
07-27-2011, 06:36 AM
on
The rims on my 07 GMC fit my 79 dent after I used the die grinder to open up the center by about 1/8".
The 4" lift should be enough to clear the 37" tires though.
07-27-2011, 07:44 AM
Quote:
Originally Posted by
outlawkyote
You have to be real careful doing something like this because you could cause the wheel to be out of balance itself.
07-27-2011, 07:50 AM
on
outlawkyote
You could also damage the wheel to the point where it might crack and if your hauling heavy loads might not stand up to the pressure after being modified.
S
07-27-2011, 11:49 AM
on
Yeah, Ive heard all that before. Were only talking 1/8 inch and it was mosdtly in the stamped crease. Im still running them on my jimmy and pulling gooseneck trailers that are well overloaded, no problems yet. Thanks for the warning though
07-27-2011, 02:28 PM
on
A 4 inch lift would put you at a stock highboy height so I think that would be the Max height for your truck unless you wanna start trimming fenders.
02-06-2012, 07:31 PM
Anyone know if the 12.50" wide Hummer tires will fit a stock 16.5x7" rim?
02-06-2012, 07:58 PM
on
twinzilla
yup 37 inch humvees on stock HB wheels
EDIT: this is a stock HB btw, no lift
02-06-2012, 08:01 PM
on
jbarefoot
the back spacing is was too much (or too little?) you wouldnt be able to turn for ****. so guys re center the wheels
see here, you can see my questions as i wondered the same
12bolts I've been working on.... - FSB Forums
02-06-2012, 08:36 PM
impalaslayer
Cool thanks, they look good on the stockers
heikks
02-04-2013 07:01 PM
Steve2916
04-04-2012 03:46 PM
tripleup05
24
12-20-2005 03:34 PM
snagmaster86
02-21-2005 11:11 PM
Screamin T/A
02-20-2003 09:09 AM
37 ,
66 ,
davidson ,
f250 ,
f350 ,
fit ,
ford ,
h1 ,
harley ,
hummer ,
inch ,
powered ,
rims ,
truck ,
vbulletin ,
wheels
