Thanks for all the help. I ended up changing the coil, cap, and rotor. And the + side of the coil had a pretty nasty looking splice so I fixed that. It fired right up, drives great! I still found a few issues I need to take care of, but it's working.
Good deal, when someone replys with the actual fixes it helps.Its good when symptoms and problems are solved and listed . Remember the search catgory helps also . Good luck TR
