Clearing ECM codes
Old Sep 13, 2004 | 04:45 PM
fireman751's Avatar
fireman751
Clearing ECM codes
I have a 1993 F150 with a Inline six. The check engine light was coming on and my truck was getting terrible gas mileage (12mpg). Auto Zone pulled codes for EGR position sensor and O2 sensor. I have replaced both sensors but still have the check engine light. How can I clear codes???? I have tried the battery disconnect and the truck still has check engine light coming on. Thanks...
Old Sep 13, 2004 | 05:11 PM
andym's Avatar
andym
If you've disconnected the battery, then the computer has been reset. Sounds like there's something wrong with it still. You can pull the codes yourself with a paperclip.
Old Sep 13, 2004 | 05:49 PM
mike L's Avatar
mike L
You should also leave the lights on for about 10 minutes after you disconnected the battery. Or go for a ten minute drive. You could go back to autozone to have them clear the codes.
Old Sep 13, 2004 | 06:10 PM
EPNCSU2006's Avatar
EPNCSU2006
If you do the paperclip method of pulling the codes, all you have to do is pull the paper clip out while the codes are blinking to erase the codes. As long as the battery is disconnected for 10 minutes or so, it will reset everything in it - all the adjusted operating parameters and codes - you don't have to turn on the headlights or anything like that (OBD-II is another story, but doesn't apply here).
nitrored
1997 - 2003 F150
Oct 3, 2016 05:03 PM
AlZipp
6.7L Power Stroke Diesel
Jul 6, 2016 05:38 PM
jrvance7
Modular V8 (4.6L, 5.4L)
Jul 27, 2011 05:13 PM
nealneu
Mar 30, 2011 11:15 AM
eigenvector
1983 - 2012 Ranger & B-Series
Nov 15, 2009 11:24 AM
