Replacing Leaf Springs on 1950 Ford F1
WOW. This was among the most helpful of threads. The 64 year old pins are out! Many thanks Stu for the puller idea. I have to admit that I semi ignored your instructions and grabbed a cheap bolt at the hardware; I managed to shear off a 1/2 bolt w/a breaker bar I went to the fastener shop and got a grade 5 bolt and out she came. My deepwell sockets are shaped in a way that I couldn't get the bolt through, so here I am with my small socket and a bunch of wrenches as spacers to add to the throw of the puller. Got both my axles out today, happy man.
You guys make this way too hard. If you remove the grease fitting, the hole in the pin has a 1/8" pipe thread. Take an appropriately sized grade 5 bolt, like a 1/2" x 10 tpi IIRC, put a grade 5 or 8 nut on it screwed way up high, grind off the original threads up about 1/2" from the end, then rethread the end of the bolt with a 1/8" pipe die. Put a big flat washer behind the nut, slip it over an appropriately sized socket (13/16" IIRC), screw the grade five bolt with above assembly into the grease zert hole, then put the torque to the nut against the washer and socket. Depending on how worn the pin is, it will fight you, and might need some heat and a BFH, but it will come out. Sure is easier than laying on your back making holes in your frame and swinging that BFH upside down. Stu
Edit - the bolt used is a 1/2" x 13 tpi grade 5. You also have to add threads up the shaft an inch or so to give yourself enough depth to clear the socket. Stu
WOW, that's freaking awesome. My truck does have holdes in thie cross member support already and they look factory but this method is easier anyways. Learn something new all the time.
86F150302
26
12-30-2016 08:25 PM
1985 Bronco
1978 - 1996 Big Bronco
18
09-19-2016 10:50 PM
kaotikedge_111100
22
05-25-2016 12:48 PM
