400+ hp 351w build
400+ hp 351w build
So what's it take to hit that with a stock bottom end bored .030 over?
Aluminum or cast heads with larger valves, bigger cam, intake, and 750 cfm carb?
Here's what parts I was looking at.... Just not sure if its good for my goal.
Edelbrock 60259 - Edelbrock Performer RPM Cylinder Heads - Overview - SummitRacing.com
Lunati 00111LK - Lunati Bracket Master II Cam and Lifter Kits - Overview - SummitRacing.com
Scorpion Performance SCP1019BL - Scorpion Race Series Rocker Arms - Overview - SummitRacing.com
Summit Racing SUM-226036 - Summit Racing Street & Strip® Stage 2 Intake Manifolds - Overview - SummitRacing.com
Summit Racing SUM-M08750VS - Summit Racing Street & Strip® Carburetors - Overview - SummitRacing.com
What do you guys think?
on
Everything you need to know is right here.. https://www.ford-trucks.com/forums/1...51w-build.html
Motor is new. Less than 8,000 miles on it. Its a lot better now with the 5.8 5 speed and 37s vs the old 5.0 E4OD and 33s (all with the 4.56s)
I don't want to drop to lower than 4.56s. One reason, is that I would have to use a notched cross pin in the rear axle due to how thick the gears are. And that would also make my assie locker unusable in the pickup. I also don't know how much of a difference the gears would make. I didn't see much of a power difference between 3.35s ans 4.56s when I had the 33s
to bad you couldnt find one of the fsb guys there in your neck of the woods that had a rear end with 5.13's that you could just swap over to drive and see how it works out. the swap would only take a couple hours but would be worth the time/effort.
the ZF is just like the NP435. you dont use 1st gear on that tranny either. you start out in second gear.
Airflow Research (AFR) 1492 - AFR 185cc SBF Outlaw Street Heads - Overview - SummitRacing.com
Or how about these? http://www.summitracing.com/parts/DRT-13301111
Swatter
13
10-17-2012 08:16 PM
f250custom78
08-18-2012 12:52 PM
f100beatertruck
02-24-2012 01:11 PM
Fordenthusiasts
01-24-2012 09:23 PM
Kirbys73F100
07-29-2010 12:06 AM
