FORD F-250 Brake pedal sucked!
Other possablity is the ECU is relearning the idle and that should take a few mins for it idle down as the ECU learns.
I made that at my last job, where I made large vinyl signs for tractor-trailers the company owned.
Right after I got this truck I couldn't believe how damn big it was so I named her "Beast". I reversed it so people in front could read it as I came up on them at stop signs and filled their back window with only a view of her grill LOL
bykrmom: Really? That's nice fo you. Thanks!!!!... How much is the machine you need?
Eddiec1564: It idals normal when I first start the truck. Once into gear then back into park it is at 2000Rpms.
andym: All new hoses are on the truck. I will be doing some hard work on this truck from the looks of it.
Thank you all for your help!
my truck idles any where from 1k to 1.5k so 2k doesn't seem too terribly abnormal but its a concern, have you checked for vac leaks yet, does your truck hesitate or act funny in any way shape or form when driving it?
@bykrmom: could i get some made for my rig too? and jump in on that action too?
on
I have to save a couple hundred dollars for the digital cutter, and then a few more bucks for a variety of color of vinyl. Sadly it can't happen until I buy new ball joints and a new radiator for Beast.
When I can finally purchase the cutter and vinyl, I'll start a thread and will only charge for the actual cost of the vinyl to make them for FTE members. I have an extensive file of fonts and vector images so it could be fun to help you guys and gals dress up the rolling stock
At the moment my income is all just unemployment, so it's very small. Smaller yet because this F250 is falling apart in my driveway! I seriously love this truck, but at some point it is going to have to stop eating cash!
I'll let you all know when I can get it all together.
First, you can call me Angie...
I'm not working due to injuries but I'll be back to work by the end of the year so my income is limited as well. I had to put an engine in my 250 recently which was tough to swallow at first but since then (about a month and a half) I've made over $4000 working the truck and have plenty more to do. I've actually turned down a few lower paying jobs. I had the jobs lined up already though, and already had several loads of scrap and enough flea market items to last all year. Otherwise, I may not have taken the financial risk until I was back at my real job.
Hope you get it running good and get your income in order. Patience and faith goes a long way
on
It's harder to keep the faith now, as it's been a year since I last had a job. I keep looking and looking, but everyone around here wants to pay peanuts compared to my last job. But I try to remain positive
Again, good luck!
First, you can call me Angie... bykrmom is just the name log in with...a throwback from when I had a small bike shop
Ah, could be the Idle air control(IAC) hanging up, usually they hang up all the time and not idle down. But I had some do wierd things like that. Good time to take it off and clean it out. If it still does the rev up, unplug the IAC while the engine is at the high idle, if it drops down to base idle(under 600 rpm) then there could be a ECU or wire problem to the IAC.
Skyforum
16
06-14-2018 09:19 PM
AJP
1999 to 2016 Super Duty
25
05-23-2012 01:21 AM
akboy350
03-21-2012 09:36 PM
DillonZ81ford
03-02-2011 07:57 PM
