I bought an OEM from the dealer but Im having trouble pulling the axle.
Do you have experience with this?
Did you take the 5 bolts on the end of the axle out.If you did that the axle should com wright out.If not tell me what you did so far.Matbe I can help you.
I am not sure if you can find any aftermarket parking brake, but did you try to adjust what you have?
I had mine pretty weak at 260k miles, but than I adjusted the slack and now it will hold 20k lb set on pretty steep hills.
Its the left side axle (the one closest to the ring gear).
Ive removed the 2 bolts holding the bracket over the left bearing.
Am I to remove the bolts on the housing for the planetary gears?
Remove the center cap from the rear wheel there be a hub that sticks out.There will be 5 maybe more bolts around it remove those bolts that is the axle it will pull straight out.
I looked again. I need to remove the hub that has the bolts for the wheel lug nuts.
I need to remove this in order to replace the emergency brake.
If removing the 8 bolts from the center cap will allow me to remove the entire hub/axle then Im in good shape.
