2002 4.6 rough idle - poor fuel economy
Hi all. I have had this problem for a while and it's driving me nuts.
My 4.6 idles pretty rough most of the time. It also is using a lot of gas and seems to have a little less power than I'm used to. The truck has 100 000 miles on it.
So far I've replaced two bad COPs and the spark plugs last year. A scan shows no codes and the CIL is off. However, when I scanned the sensors the O2S12 O2 sensor is constantly reading 0 volts. This doesn't seem right as the other post cat O2 sensor reads a varying voltage. I'd guess that the sensor is bad but there is no code showing up. I also noticed that I have a slight exhaust leak in the joint on the crossover pipe.
Any suggestions before I start by replacing that O2 sensor?
NinthGenF-SeriesOBS
2004 - 2008 F150
05-03-2016 08:15 AM
Chris Chap
3.8 & 4.2L V6
04-15-2016 08:54 AM
joners
02-08-2006 05:26 PM
KTMNealio
04-27-2000 03:02 PM
