rear blinker doesn't work
07-15-2011, 05:30 PM
My rear passenger side blinker doesn't work. Brake light on same side doesn't work, but the regular light does. I changed the bulb already thinking it was that filament, but no. The dash flashes normally and the front on the same side works. Bad socket? thanks
07-15-2011, 07:11 PM
could be a bad socket, or a bad pigtail in the socket, or even a pinched/cut wire from the cab to the light.
07-15-2011, 07:42 PM
would a cut/ damaged wire allow half the bulb to work?
07-15-2011, 08:36 PM
07-15-2011, 08:57 PM
I'll recheck the ground. thanks
07-15-2011, 11:14 PM
Refill the Blinker Fluid Resevoir.....Sounds like its low...
ROFLMAO
07-15-2011, 11:18 PM
Check the bulb...(I'm being serious now)...
If its a 3156 bulb, they have a single filament...3157's have a dual filament.....
Just a SERIOUS thought....
07-16-2011, 07:23 AM
there are 3 wires going to the rear light.
running light wire
blinker/brake light wire
ground wire
07-16-2011, 02:05 PM
Blinker fluid is full sidewinder
It's a 3157 bulb, so I'll follow the wire that runs the blinker, Thanks
07-17-2011, 02:20 AM
Quote:
Originally Posted by
george1016
Dual filament....Check the bulb; See if one of the filaments is broken....
rossseger
1999 to 2016 Super Duty
11-03-2014 02:09 PM
gimmeagig
17
07-01-2013 10:33 PM
69monster
04-22-2010 12:51 PM
69monster
Electrical Systems/Wiring
04-16-2010 02:13 PM
cjf5150
10-18-2005 11:18 AM
06 ,
79 ,
blinker ,
blinkers ,
brake ,
bronco ,
ford ,
international ,
light ,
truck ,
wont ,
work
