A little from the darkside.....very little!!
I haven't posted much lately for a variety of reasons, cutting lots of grass, too dang hot, fte site won't load, etc....etc....etc...and maybe just a touch of lazy to go with the summer heat. Enough with the excuses.....
I've got 3 grilles to choose from for my build, a stock 55, a stock 53, and a 53 grill that was badly abused. I've got the stock 53 grill blasted and body worked and currently in primer, the 55 hasn't been touched, and the mangled 53....I've started some surgery on.
I'm still looking at the modified 53 grille and scratching my head as to where to take it. I'm inclined to cut out part of the lower portion of the grille and add a few thin aluminum bars. I'd also like to french the headlights. Any thoughts on the modified grille would be welcome.
The other two grilles are safe. Their condition is too good to cut them up.
I'm using a GM steering column, so I built a column drop out of 14 ga stainless. I fashioned several patterns out of wood to determine how I wanted it shaped, transferred the pattern to my stainless..........
I cut a 3/4" band to run around the perimeter of the drop and tigged it together.
And after a bunch of grinding and polishing.............
Now I gotta lose that key and make a cover for the lower portion of the column.
I've also made an attempt to start installing my bear claw door latches. I don't know if this is going to work, but I wanted to mount the striker bolt without performing a lot of metal surgery in the door jamb. (Probably sounds like an odd statement with as much slicing and dicing as I've done on this build.) I cut out a piece of 1/2" stock with the same shape as the stock piece.
A trial fit..........haven't countersunk the mounting holes yet.
By using the stock mounting system, I can adjust the striker bolt position by loosening the screws. If anyone has done this before, how did it work? It would be no big deal to go to "Plan B" if this is a bad idea. Or maybe "Plan C".
small bottom grill teeth would look killer on the center of that grille, they were used on some mercs and i believe on some`53 f100`s, Keithcruise has them on his grille.
Really like your door striker idea, saves you a lot of pillar surgery! keep us posted would really like to see the finished product!!
Received 4,135 Likes
on
Looking back with that 20/20 hindsight, I should have hung on to all of those parts. But realistically I had run out of places to store them and didn't want to leave them out in the weather.
Annnnnnyway, it's good to be able to post something for a change.
[QUOTE=Drewski 2;10579073]I haven't posted much lately for a variety of reasons, cutting lots of grass, too dang hot, fte site won't load, etc....etc....etc...and maybe just a touch of lazy to go with the summer heat. Enough with the excuses.....
Hey Drew you would have an "extra" one of them column mounts around anywhere would you?
[quote=tacson;10581492]
Donald, I've probably always got one laying around, they just don't look like a column drop. Can you see that drop in the photo?
I always keep scrap metal around to build this stuff I dream up. I get a lot of various kinds of steel and aluminum given to my by people I run into. I had a guy give me a 4'x4' sheet of cold rolled steel just so he could get it out of his way. I was at his house looking at a car part he had for sale on craigslist.
The column drop stainless was another one of those freebie pieces that I picked up somewhere. My roll pans were made out of Mayline drafting table modesty panels.
I've seen some interesting pieces of steel laying in some of those salvage cars over at Auto Express.
Drewski 2
25
04-27-2014 10:40 AM
Drewski 2
93
09-07-2011 08:13 AM
Drewski 2
40
02-02-2011 05:54 AM
