COMPUTER RESETS
Old 07-11-2011, 03:01 PM
jsmitty80's Avatar
jsmitty80
jsmitty80 is offline
COMPUTER RESETS
looking for some answers on 1997 ford powerstroke!!!!!!
While driving the truck dies like you shut the key off check engine light and wait to start light comes on .sometimes it starts right back up sometimes the wait to start light will just flicker and truck wont start. truck is got a superchip intercooler and 4" exhaust,but no major mods. It fills like the computer resets itself ,PLEASE HELP!!!!!!!
Old 07-11-2011, 03:14 PM
cleatus12r's Avatar
cleatus12r
cleatus12r is offline
Butt-Head
Received 1,974 Likes on 1,108 Posts
Sounds like the chip isn't making good contact with the circuit board in the PCM. If that's the problem, you better fix it before it cooks the chip AND the PCM.
Old 07-11-2011, 06:49 PM
427 fordman's Avatar
427 fordman
427 fordman is offline
Sounds like a loose chip to me too, but isnt the superchips just a program, not a chip? Have you pulled the code? If its P0605 thats normally the code with a loose chip.
Old 07-11-2011, 10:37 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
I assumed a chip. Superchips made chips and programmers.
Old 07-12-2011, 05:41 AM
427 fordman
Thanks Cody, didn't know that.
Old 07-12-2011, 06:54 AM
Awitte58's Avatar
Awitte58
Awitte58 is offline
What they said. Probably just a bad connection...
Welcome to FTE!
Old 07-17-2011, 02:50 PM
jsmitty80's Avatar
jsmitty80
Thanks for the info. I took my computer out cleaned it and the chip ,drove it for about an hour and it worked fine. I started it the next morning headed to work and did the samething just not as bad. Do you think that the fuel bowl heater is grounding out ???????????
Old 07-17-2011, 03:18 PM
arkredneck's Avatar
arkredneck
arkredneck is offline
I think when the fuel bowl heater grounds out it blows a fuse
Old 07-17-2011, 03:19 PM
427 fordman
Did you tape the chip in? Was it loose at all?
Old 07-17-2011, 06:22 PM
jsmitty80's Avatar
jsmitty80
The chip is taped in, no it wasnt loose need to pull codes sometime check engine light stays on for a couple of mins, sometime it turn my radio off at the same time is my computer just freaking out or what???????????
DonnieP
03-12-2015 02:33 PM
Chris Anchor
2009 - 2014 F150
04-26-2010 03:26 PM
gthbryce
05-26-2009 03:54 PM
Xdrive
1983 - 2012 Ranger & B-Series
02-10-2007 05:58 PM
dentoje
12-04-2004 06:05 PM
Quick Reply: COMPUTER RESETS
