4WD hub question?
4WD hub question?
so I am under the ex doing the inspection plate anti rattle fix and grab ahold of the front drive shaft. The dang thing does not spin free! It should, shouldn't it?... thinking the factory hubs need to be replaced. They are in the auto position and again, should spin freely right?
Signed. Baffled in Bristol.
on
They should spin freely unless is is all together and the hub locked (clockwise). You don't have limited slip it the front do you?. No need to jack it up, they should both spin freely with a big screwdriver unless the hub is locked on that side.
No limited slip as far as I know, we purchased used in 05. The hubs are becoming increasingly difficult to turn from lock to auto, I have removed and attempted maintenance per guzzles instructions and photo's but I fear it is simply time to ditch the old hubs. Anybody have any suggestions on brand preference?
BTW, the hubs show as being in the auto position. This past winter I had a slight issue after switching to 4WD on the fly, it sounded like a serious vacuum leak on the drivers side. Sounded as though 2 rubber seals were rubbing together. Went away but now the hubs will not disengage manually...
on
RV_Tech
Conventional (Bumper Pull) Towing; Travel Trailers & Pop-ups
02-27-2012 12:58 PM
Greywolf
Tennessee Chapter
10-01-2005 09:56 PM
