sorry for the lack of knowledge to call it what it is, bit its the bars that anchor the outer frame.. so the truck bed doesn't wobble around..you know if i could get some picture so i can see where they go i would really appreciate it..
no... it keeps the fender in place ..its been over a year since i took'em out to get the truck bed off...here is a example <a href="http://s83.photobucket.com/albums/j291/exittrippkat/?action=view&current=DSCF0002.jpg" target="_blank"><img src="http://i83.photobucket.com/albums/j291/exittrippkat/DSCF0002.jpg" border="0" alt="Photobucket"></a>
If you have a torch you can make your own. Measure the lenght you need and cut some 3/8" bar stock and heat the ends red hot. Hammer the ends flat and bend in a vise as needed. Drill holes and mount. 3/8" rebar will work as well.
