picture request..
sorry for the lack of knowledge to call it what it is, bit its the bars that anchor the outer frame.. so the truck bed doesn't wobble around..you know if i could get some picture so i can see where they go i would really appreciate it..
sway bar ?
no... it keeps the fender in place ..its been over a year since i took'em out to get the truck bed off...here is a example <a href="http://s83.photobucket.com/albums/j291/exittrippkat/?action=view&current=DSCF0002.jpg" target="_blank"><img src="http://i83.photobucket.com/albums/j291/exittrippkat/DSCF0002.jpg" border="0" alt="Photobucket"></a>
Those are just fender braces. They don't go to the frame they bolt to the box crossmembers.:-X22
http://i95.photobucket.com/albums/l1...-2011027-2.jpg http://i95.photobucket.com/albums/l1...18-2011030.jpg |
In front of the tire:
http://i1197.photobucket.com/albums/...976F150005.jpg http://i1197.photobucket.com/albums/...976F150006.jpg http://i1197.photobucket.com/albums/...976F150007.jpg Behind the tire: http://i1197.photobucket.com/albums/...976F150008.jpg http://i1197.photobucket.com/albums/...976F150009.jpg Hope that helps! |
If you have a torch you can make your own. Measure the lenght you need and cut some 3/8" bar stock and heat the ends red hot. Hammer the ends flat and bend in a vise as needed. Drill holes and mount. 3/8" rebar will work as well.
right on fellas :-drink keep up the good work:-X22
