SuperChip For 4.2L V6 F150 ???
So I got a <a href="http://www.motorhaven.com/">Superchip</a> off ebay for cheap. It's blue, it has a number on the back, 001147. I looked on <a href="http://www.motorhaven.com/"><a href="http://www.motorhaven.com/">Superchip</a>s</a> website but they don't list all the numbers of thier chips. Anybody know what this chip can fit? and can they be easily reprogrammed to work with any engine?
I installed the chip and it did NOTHING. So I assume it's the wrong chip.
Thanks in advance for any info.
on
That number is a serial number. The chip has to be programmed for your truck's specific ECU code. Simply matching the year, model, engine and tranny isn't enough. The chip can be programmed any Ford gas engine, 1986-present (except V10s).
In order for us to reprogram the chip we'll need the ECU code. Its three letters followed by one number (example: YEU2 or SNL3). You can find it on the passenger side door frame on a <a href="http://www.motorhaven.com/">sticker</a> nears the hinges. If the <a href="http://www.motorhaven.com/">sticker</a> is gone, remove the passenger side kick panel and you'll need the computer behind it up on the firewall. The code will be on a <a href="http://www.motorhaven.com/">sticker</a> on the side of the computer box facing the back of the truck.
on
AAT3 is the code, assuming your truck's computer has not been reflashed at some point. Yes, we can reprogram all Ford <a href="http://www.motorhaven.com/"><a href="http://www.motorhaven.com/"><a href="http://www.motorhaven.com/">Superchip</a></a>s</a> modules. If it is a very old chip it may not have a large enough ROM for your truck's computer --- if that is the case then you bought a useless chip (it will only be usable on older Fords).
Pricing is here:
http://www.motorhaven.com - go to the <a href="http://www.motorhaven.com/"><a href="http://www.motorhaven.com/">Superchip</a>s</a> section.
Pricing is here:
muffett
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
04-25-2003 03:16 PM
orangeford
04-01-2003 10:54 AM
wamp12000
03-28-2003 05:00 AM
