1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
2004 6.0D Throttle position sensor
Old 06-28-2011, 02:53 PM
HowarD1's Avatar
HowarD1
HowarD1 is offline
Recently on two occasions I pressed the accelerator clear to the floor with no response. After shifting into Park then back into Drive it drove normally for about a week. Now it has stalled out and was very stubborn to restart. Once running, the accelerator will sluggishly rev the engine while in Park, but in Drive, will not respond. TPS sensor or something else?
2004 6.0 Diesel, 75K miles, no mods, well maintained.
Old 06-28-2011, 02:57 PM
raidscsi's Avatar
raidscsi
raidscsi is offline
I have a 6.8L V10, I replaced the TPS, <$25 at AutoZone, two small bolts, <10 minutes.
It's worth replacing just as a diagnostic method.
Old 06-28-2011, 03:15 PM
HowarD1's Avatar
HowarD1
HowarD1 is offline
I have made inquiries at a local diesel repair shop and was quoted a price of >$700 for parts plus labor. They told me that since I have the adjustable pedal, that I have to replace the entire pedal assembly??? I found the sensor itself online for <$50. It looks to be the replacement for the part located on top of the engine. I have read about testing the voltage. I assume that means testing the voltage of the sending unit at the pedal to eliminate that from the potential problems. Will try that and post results.
Old 06-28-2011, 04:51 PM
dchamberlain's Avatar
dchamberlain
dchamberlain is offline
Diesel engines do not have a Throttle Position Sensor on top of the engine, because they don't have a throttle.
They have an Accelerator Pedal Position sensor that is part of the accelerator pedal assembly.
You will get a better response if you post down in the 6.0L Diesel section.
Old 06-28-2011, 05:48 PM
Kajtek1's Avatar
Kajtek1
Kajtek1 is offline
Originally Posted by dchamberlain
Diesel engines do not have a Throttle Position Sensor on top of the engine, because they don't have a throttle..
Ditto on that.
The PEDAL POSITION SENSOR is pretty tricky on Ford. My is having glitches for over a year and I already bought 2 after-market PPS that didn't work. The only option is a dealer and since my PPS comes with bracket assembly the price was $170.
Bottom line, beware of after-market stuff. Even from recommended forum sponsors.
Old 06-28-2015, 02:04 PM
Porky521's Avatar
Porky521
Porky521 is offline
Replaced pps
I replaced pedal position sensor basically the gas pedal on a 2006 f250 6.0 now won't start any ideas
Dadruma
03-14-2017 06:45 PM
mhofmann86
09-22-2015 03:45 AM
Headviking
04-20-2015 10:28 AM
dvldog13
08-06-2013 12:24 PM
s_herod
01-20-2010 12:48 PM
Quick Reply: 2004 6.0D Throttle position sensor
