Bypass or simple shutoff in heater core line?
Old 06-26-2011, 09:52 AM
EMD_DRIVER's Avatar
EMD_DRIVER
EMD_DRIVER is offline
My e99's heater core decided to spring a leak the other day. Not having time to replace it, I cut both hoses and bypassed it, as a temporary fix. I've heard that it's not a good idea to simply shut off the flow, and that a bypass should be installed. I was looking at farmboy's classified ad for his e99 and noticed that he has a ball valve in one of the heater lines:
Is there any problem doing it this way?
Old 06-26-2011, 10:01 AM
hotroddsl's Avatar
hotroddsl
hotroddsl is offline
No problem at all you don't need to install the valve!You can just loop to the head with no problem until you need a heater you'll be fine
Old 06-26-2011, 10:06 AM
EMD_DRIVER's Avatar
EMD_DRIVER
That's what I did.. I cut both hoses and connected them together.. I was taking my daughter to the doctor and needed a quick fix. I just wondered if it would screw up the water pump, if I simply put a shutoff valve in when I put the new core in. I can't believe how much colder my A/C is now!!!!!
Old 06-26-2011, 10:12 AM
hotroddsl's Avatar
hotroddsl
You may experience evaporator core freeze up on humid days but if you just keep it on normal a/c not max ,no recirculate, you should be ok!
Old 06-26-2011, 10:14 AM
EMD_DRIVER's Avatar
EMD_DRIVER
Haven't had that problem yet and we've had some pretty humid days lately! I will keep that in mind though... Thanks!
Old 06-26-2011, 03:28 PM
ff1210's Avatar
ff1210
ff1210 is offline
core
Heater valve off a ford ranger works good but you cant shut it off unless you turn the a/c on. Do a search on cold a/c modd
Old 06-26-2011, 05:02 PM
EMD_DRIVER's Avatar
EMD_DRIVER
I put one of those in my 93, but would rather use a simple shutoff valve if possible. The ranger valve is vacuum actuated.
Old 06-26-2011, 05:06 PM
hotroddsl's Avatar
hotroddsl
The vacuum actuated valves automatically open when you turn on max a/c to prevent evaporator core from freezing on on humid days that's what it's there for
Old 06-26-2011, 05:23 PM
ff1210's Avatar
ff1210
ff1210 is offline
a/c
Mine opens when you turn it to vent,norm a/c, and max a/c all three.
Old 06-26-2011, 05:44 PM
hotroddsl's Avatar
hotroddsl
Does your truck have the climate control?my '07 does an it will open and close with demand on that system, but on the '02 it just stays closed when A/C is in normal but opens in max it is also open in the vent settings. I have always assumed it was a factory installation! But I could be wrong, as I'm not the original owner.
Old 06-26-2011, 05:53 PM
ff1210's Avatar
ff1210
ff1210 is offline
a/c
No my truck dont have climate control on it. Know it mite close after a will of use but you can turn it to vent and get out and look at it and watch it close, then turn it off and then back to normal ac and watch it close, and the same when you turn it to max ac not saying it stays open all the time iv just not ever sene it open on eather of those setting..
Old 06-26-2011, 06:00 PM
hotroddsl's Avatar
hotroddsl
Weird! Mine closes tight soon as you select normal ac, if you adjust the temperature I wonder if it will open? Mine is a ford valve and has all the ford style lines going to it but it is the only spot on the truck with stainless hose clamps, not the ford stock ones!
Old 06-26-2011, 06:35 PM
ff1210's Avatar
ff1210
ff1210 is offline
ac
I placed mine about 6'' from the fire wall were the two lines run to the heater core and ran the vac line to the red one under beside/behind the glove box. but ill check about moving the temp control and see what happins.
Old 07-27-2011, 09:33 PM
ronjon95's Avatar
ronjon95
ronjon95 is offline
Bump need update!
Fixnstuff
11-12-2018 11:23 AM
annaleigh
01-14-2016 09:22 PM
Josh726
1997 - 2003 F150
16
12-18-2015 09:36 PM
Bubba Jones
1978 - 1996 Big Bronco
24
03-19-2014 10:55 PM
wash31570
1997 - 2003 F150
11-30-2010 02:44 AM
Quick Reply: Bypass or simple shutoff in heater core line?
