1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
315 75 r16 will they fit a stock 2005 4x4 excursion
Old 06-23-2011, 04:13 PM
waterbuzzard's Avatar
waterbuzzard
waterbuzzard is offline
I have a stock 2005 4x4 excursion. Im currently running 285 75 r16 BFG A/T. I need new tires, looking to replace them with 315 75 r16 with a 16x8 wheel. I dont want to do anything to the suspension, just fill out the wheel well. Can it be done? Also what wheel spacing do I need on the 16x8 wheel. Thanks for the inputs.
<!-- / message -->
<!-- controls -->
Old 06-23-2011, 07:16 PM
BigPigDaddy's Avatar
BigPigDaddy
BigPigDaddy is offline
If your X has the typical front end sag that most stock ones have, you probably won't be able to fit 315's without some rubbing. I had 305/70R16's on my F250 and they rubbed just a touch on the inner fender liner when turned to full lock going backwards.
However, if you put on a leveling kit you should have no problems clearing the 315's. I did the leveling kit on my truck and my 305's now have plenty of room.
Old 06-23-2011, 09:39 PM
waterbuzzard
Thank you for the info.
quietman
04-23-2017 11:15 PM
aj1434
12-22-2016 05:36 PM
kjephoto
13
01-25-2016 10:30 PM
waterbuzzard
06-24-2011 11:20 AM
rtazz17
09-24-2009 08:48 PM
Quick Reply: 315 75 r16 will they fit a stock 2005 4x4 excursion
