1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
2000 vs. 2010 F350 turning radius
Old 06-21-2011, 08:22 AM
irhunter's Avatar
irhunter
irhunter is offline
So, I am used to driving 2000 F350 crew cabs (SRW and DRW). I recently spent time driving a 2010 F350 DRW crew cab and it seems the turning radius is way smaller on the 2010 (these are all pretty long wheel base trucks...maybe 180", or so). Was there a front-end re-design, or am I imagining the difference?
Roy
Old 06-21-2011, 08:46 AM
Zmann's Avatar
Zmann
Zmann is offline
once the front leafs became coils in 05 turning radius was improved
you can imagine why
Old 06-21-2011, 09:16 AM
irhunter's Avatar
irhunter
irhunter is offline
Thanks! I thought it must have been some major thing. Coils in '05...right.
Roy
Old 06-21-2011, 09:49 AM
bpounds's Avatar
bpounds
bpounds is offline
Originally Posted by irhunter
...spent time driving a 2010 F350 DRW crew cab...
The '08-'10 dually had a "wide-track" option available that provided an even tighter turning radius than the '05 and up. You might be driving one of those.
https://www.ford-trucks.com/forums/6...ide-track.html
Old 06-21-2011, 05:30 PM
irhunter's Avatar
irhunter
irhunter is offline
Thanks Bill,
That's interesting about the wide track. From the pics, I don't think the truck I was driving had that option....but, it sure did turn well. Time and time again I would approach a turn-around situation, while pulling a good size 2-axle trailer, and just bust out the turn without any fill/backfill. Very different from the 2000 F350s.
Roy
Old 06-21-2011, 05:44 PM
Zmann's Avatar
Zmann
Zmann is offline
I have seen images and I couldn't tell the widetrack from non on the duallys?
not having leaf springs for the tires to hit was decent plan plus the coils ride softer IMHO
but I still have 2 front leaf sprung vehicles so Im not bagging on them lol
Old 06-21-2011, 06:03 PM
irhunter's Avatar
irhunter
irhunter is offline
Well Z,
I could easily be imagining the difference I see in the pics. There is one pic from a straight-head-on view that makes me think I can see a couple inches difference. It would be best if there were side by side pics.
Is the extent of front-fender flare the same on wide track trucks?
Old 06-21-2011, 06:05 PM
Zmann's Avatar
Zmann
Zmann is offline
maybe the flare is bigger? I was tring to find side by side pics
I guess if we had the wheelbase specs we could see how much wider they are ?
Old 06-22-2011, 09:10 AM
Furian's Avatar
Furian
Furian is offline
You Keep What You Kill
From the link below (Page 70 - STEERING SPECIFICATIONS), it appears that the F450 Crew Cab Long Bed has a slightly smaller turning radius (Curb-to-Curb & Wall-to-Wall) than the F250 Regular Cab Long Bed due to an enhanced 18:1 gear ratio versus the standard 17:1 gear ratio. Amazing!
https://www.fleet.ford.com/truckbbas...kups_PRINT.PDF
Old 02-18-2012, 07:46 AM
curioduo's Avatar
curioduo
curioduo is offline
Modifying 97 F350 CC?
So how difficult is it to modify the suspension on a 97 F350 crew cab to go from leaf to coils?
nvetro
2017+ Super Duty
130
07-14-2019 07:27 PM
Captkservices
2017+ Super Duty
09-05-2016 12:48 PM
Glockem45
6.4L Power Stroke Diesel
44
04-04-2016 08:51 PM
HAMMERDOWN103
38
01-24-2013 05:13 AM
Quick Reply: 2000 vs. 2010 F350 turning radius
