Clutch Tool
Old 06-20-2011, 09:21 AM
john fin's Avatar
john fin
john fin is offline
Clutch Tool
When installing a clutch plate on my 49' f2 with 4 speed, do I need a pilot alignment tool? and if so where would I find one?
Old 06-20-2011, 10:14 AM
chriscris's Avatar
chriscris
chriscris is offline
Not sure where you would find one, but you should use one. (maybe NAPA for a universal one?)
There are the universal type or some aftermarket clutch kits come with a specific one.
I've done it b4 without, but you have to be dead bang on.
Old 06-20-2011, 10:33 AM
r_reed's Avatar
r_reed
r_reed is offline
Clutch Alignment Tool - Speedway Motors, America's Oldest Speed Shop, although napa prob has or can get one. guess you need to know application.
Old 06-20-2011, 11:18 AM
52 Merc's Avatar
52 Merc
52 Merc is online now
Received 2,451 Likes on 1,398 Posts
Frankly, I've always had better luck doing it without. I will feel around the edge of the pressure plate and compare that to the edge of the clutch disc, and make sure it's even all the way around. When it's just right, I put the final tighten on the PP bolts. The weight of the disc on the alignment tool always seems to let it fall down a bit. At least, that's been my experience, but I don't do it every day, either.
