Will this cam work well?
Old 06-20-2011, 12:36 AM
460's Avatar
460
460 is offline
Swapping a 460 into my 2wd '93 Ranger and I'm trying to match all my parts.
It will have built C6 with whatever converter is needed. Stock height tires with undecided gear ratio, but possibly 3.08
The 460 is a D0VE-A block, D0VE-C heads, wanting a Stealth intake, has a 750 AFB carb.
How well will this cam work? Lunati 11602LK - Lunati BareBones Camshaft and Lifter Kits - Overview - SummitRacing.com
Old 06-21-2011, 12:05 AM
mark a.'s Avatar
mark a.
mark a. is offline
What pistons ? what comp ratio ? If you use that cam check retainer to guide clearance,amoung all the other things to check.
Old 06-23-2011, 12:22 AM
460's Avatar
460
460 is offline
Stock pistons. From what I've read and been told, I should be around 10.5 to 1 compression. The block, pistons, and heads are all pre-smog.
