SD Vacuum Pump
SD Vacuum Pump
Anyone know what it all takes to switch to the superduty electric vacuum pump? I'm installing a custom high-flow powersteering pump from AGR along with gear box, cooler, and hydroboost, and it appears the new resivoir on the pump isn't going to clear the vacuum pump. So either I gotta make a new bracket and reclock the pump, which is iffy because I don't want the resivoir sitting too sideways, or I gotta remove the pump and go electric. Any thoughts?? It appears all that the vacuum pump will need to run anymore is the heater controls.
73Strokin is it possible to run a remote resivoir style pump? Might solve your issue. I swapped mine to hydro-boost couple years ago and stuck with the stock pump so I had no clearance issue.
Like TJ swapping to Electric Vac pump has been on my list for a while. Finally had to break down and replace my vac pump so my air vents would work. Now it sucks .. HAHA
Since you brought it up I do believe a remote resivoir would solve the problem, as would the electric vacuum pump. I guess either way you'd have to do something, but both are viable options depending which way you wanna go.
Does anyone know if removing the vacuum pump takes a lot of load off the engine? Or if I ain't using as much vacuum will the pump not put as much load on the engine? Just wondering because if removing the vacuum pump don't make much difference in engine performance, maybe its just easier to go remote ps resivoir instead of finding an idler pulley setup.
Obviously I'm looking to swap to an electric vacuum pump because of space constraints, but under normal circumstances, what are the benefits of doin the electric pump?
blackturbo
09-13-2014 11:00 PM
