rear abs/parking brake light on; why?
i started my truck up a few days ago, and the red parking brake light came on, along with the yellow rear anti-lock light. any ideas? brakes seem fine, although i haven't torn em' apart yet. my parking brake is frozen up though, and has never worked since i bought the truck. i tried pulling the release, but it didn't help. thanks for your input
Try checking your fluid level for starters,
then look for obvious things like leaks around the master cylinder, brake lines, wheel cylinders, proportioning valve.
If this fails to solve your dilema, then you will have to pull the codes from the computer.
Well hope these tips help....
Mat Plante
1987 F-150 EXT Cab
Base Model w/ 302EFI
A0D with 3.55s
Pioneer Sound System
connork
03-24-2013 06:52 AM
Confederate Diesel
01-04-2011 10:14 PM
tbbucs1908
01-12-2010 03:18 PM
avenge
06-12-2009 06:24 PM
