wierd grinding noise in front end.
i went through this about 4 months ago. turns out the 'grinding' was the downpipe contacting the firewall when in a left turn (didnt do it turning right). it sounded identical to grinding. took it apart, bent the crap out of the firewall some more, and voila... no more noise!
funny story sort of related... while i was in the process of tracking down the grinding i found much to my dismay that the driver side leaf spring center pin was literally worn in half and not holding anything together and the drivers side front axle was moved forward by about 3/4" scared the **** outta me! i quickly fixed that.
-cutts-
-cutts-
It still could be the hubs. If it's a grinding noise then it's something that's turning, not a ball joint or tie rod end. Maybe you or whoever put the hubs back together last time did it wrong. It happens. I've seen the big spring put on the wrong side of the gear lots of time and that spring left out too. That will make a grinding noise when you hit bumps.
Hussler, I have this issue with my truck, sharp turns slow speeds uneven surfaces makes this pop/grinding noise. Now it progressed to anytime i hit the brakes reasonably hard it makes a brutal grinding, squeaking sound identical to a bad brake pad but thats not the problem they are newer. Also my 4x4 isnt working properly, i have auto hubs when i put it in 4x4 hi, I cant go over 35 without it grinding. not even sure if both fronts are engaging. 4x4 low goes in but you cant go over 10.. pretty sure thats standard tho right? Not sure what my nxt move should be. 1997 Ford F250 HD 4X4 auto hubs thanks- Brett
on
1 Post
That same thing happened to me because my Radius arm bracket was messed up and the bushing was chewed up pretty good.
Shutter vibrations when hit bump going forward
So im loosing ny faith in my ranger
i drive at 30 moh straight hit snall bump not big ones and i get a vibrstion shutter that will nit stop till i slow down to 5 mph or if i turn on 4high . I checked everything finally just said screw it tried hud assembly and it stopped for a couple days has returned but alot less now. While changing the assembly i broke pulse hub so i took the other out two (hope it doesnt cause any damage). So when it started again i did same to stop it i flipped into 4x4 high and it stopped even without pulse hubs in. Help
[QUOTE=RRranch;10462776]It still could be the hubs. If it's a grinding noise then it's something that's turning, not a ball joint or tie rod end. Maybe you or whoever put the hubs back together last time did it wrong. It happens. I've seen the big spring put on the wrong side of the gear lots of time and that spring left out too. That will make a grinding noise
Vince79vette
12-26-2016 03:02 PM
