Transmission EPC sensor. Please help
I'm sure you all know by now I'm having transmission problems.
After doing much reading around and talking to people
I have really started to think my epc sensor or valve in my transmission is bad. From the symptoms other people have been having because of their epc sensor going(slipping,hard shifts,no gears at all)
Im having slipping and hard shifts.
Does anyone think it could be that? Is there a way to test it? And how had is it to replace it...the thought of spending 3k right now sucks.
Thanks in advance.
Thanks in advance.
There is no EPC sensor. There is an EPC solenoid. EPC means Electronic Pressure Control. This solenoid controls pressure in the transmission.
There is a test port on the side of the transmission. The shop manual has expected pressures for each gear. You need a 0-400 PSI gauge to check it.
You've probably checked theses basics Allready but.. Any sparkled in he tranny fluid on the dipstick. You could pull the cover off the torque converter and check for end play and broken flex plate (not likely but quick) metal in cover. And drop pan and check for small parts and shavings/sparkles here. Are you FWD? Might try shifting 2-4 and try to determine of it is xmsn or xfer. I suspect leak you mentioned earlier is the best clue though.
RIKIL
27
06-29-2016 04:44 PM
jdwoody
17
11-17-2015 08:06 PM
